hangovers and bridges
geraldtrost
Posted · hangovers and bridges
Hi all!
I am rather disappointed because the cura slicer does not look ahead, as it seems.
There could be some quite effective tricks to build overhangs and bridges
if only the slicer would look some layers ahead.
ideas:
- print the overhang from inside to outside
(the overhang starts with a "shell" at its bottom, this is
100% filled. if printed from inside to outside then the
overhang would come out much better -
but the slicer would have to make localized decisions
about what is the local inner side and what is the
local outer side)
- print small partly supports below the bridge and
below the overhang
these tiny supports would then be built like a small
overhang and it would start some 10 layers below
these local supports would not reach out for the
entire width of the bridge but for about more than
half of its spread - maybe one third at the right
post and one third at the left post.
the slicer would then look some layers ahead ...
is there already a branch of cura that implements
these ideas ?
thanks
Gerald
