Ultimaker 3 Firmware SC
sambianchibazzi
Posted · Ultimaker 3 Firmware SC
I don't see what that has to do with it.
Anyway this is the correct link: http://ulti.creatr.it/en/2x/index.html and here are the guides with videos: http://ulti.creatr.it/en/support/2x/assembly.html
Yes, I haven't checked the forum recently. I'll check it in a couple of hours. If someone has any important question it would be better if they send an email in anycase.
    Well, you created a lot of buzz around your dual extruder solution and then just disappeared. And you did not answer email sent to you. Then you are surprised that people grab you at your first appearance after five months.
    However, I lost the trust in you, so for me UltiCreatr is no option anymore.
