I guess you are printing over USB? This is not officially supported for the UM2 family. Try putting your files on a SD card, and print from the SD card instead.
If you still want to print over USB, go to the Printers pane of the preferences, go into the Machine Settings, and select Reprap (Marlin/Sprinter) as gcode flavor.
Hi ahoeben,
no no until now I always printed via SD, it is the one who advised me and still is sometimes more comfortable ..
I will make the change in settings with flavor code
if I try to start a job done with SD simplify it does not show me even the meters of wire needed - only the word "unknown .."
ahoeben 1,981
ManuHC 0
Hi ahoeben,
Thanks
