We started with using the recommended settings believing these would be the best to get started. We have done the latest firmware update as of 11/29, but we had done a firmware update at unboxing. When we go into "Custom" the default retraction is 6.5mm which seems really high. After the last firmware update we noticed others complaining of the high retraction value and reset it to 2mm.
We are trying another print at the new retraction setting and it has been running much longer without loss of extrusion. We hope this one finishes with no issue.
fbrc8-erin 316
What sort of settings are you using? Are you using the advanced settings in Cura or the basic/recommended settings?
Have you performed a factory reset or updated the firmware since receiving the machine?
Is this happening across multiple gcodes?
