Posted · Difference in stl parser Cura 15.02.01 and Cura 2.3.1
Hi everyone,
I created a simple programm to design gears with an export to stl. The old cura can read the files without any problems. The new cura always tells me "Laden fehlgeschlagen" (translated: "error loading").
The syntax of my file is straight forward:
solid ZahnradMotor
facet normal 0 0 1
	outer loop
		vertex 9,627692 0 0
		vertex 7,106483 0,5494544 0
		vertex 7,127692 0 0
	endloop
endfacet
facet normal 0 0 1
	outer loop
		vertex 9,627692 0 0
		vertex 8,457993 1,702771 0
	endloop
endfacet
endsolid ZahnradMotor
Is there anything I need to change specifically for the new cura?
best regards
Florian
    You realy use , (Komma) as decimal seperator?
    Use . (Punkt) instead.
    Maybe the old parser was a bit more tolerant?!?
    Ah you are right. I wanted to try that but forgot. I will tell the result. My bad. Sorry
    I have tested it. You are absolutely right. Thank you!
