Ultimaker original (w/o plus) and ultimaker board from original plus
Posted · Ultimaker original (w/o plus) and ultimaker board from original plus
hi
the board of my original (w/o plus) was toasted yesterday in the evening. I have a ultimaker original plus board here. is it possible to use the new board on the original (w/o plus) incl. my heated bed ?
I thought about the thermosensor board which is attached on the original and dissapeared on the plus....
    Posted (edited) · Ultimaker original (w/o plus) and ultimaker board from original plus
    The only missingparts would be
    UMO+ differences
    - 24V fan for print head, yours is 12V
    - PT100 instead of thermistor+amplifier (same size should fit on the aluminum heater block)
    - No fan on board
    - Different outputs (you will need to cut a bit the wood frame and drill holes for the board screws.
    I think that's all?
    Edit. Yeah the heater umo is 18V. That shouldn't be a problem but will need some PID adjustment.
