Ok this is good to know. Just as an update in case anyone has any ideas. I put some time in yesterday and have had the following results.
I have indeed tried the z height calibration.
In fact I took the time yesterday to remove all the material and swap the two AA cores with each other. Still the auto calibration on the core 2 will not work. Doesn't matter which core is in the 2nd slot.
If I turn auto bed leveling off both cores will work at the manually adjusted height. It just seems to be the auto calibration should work.
I checked the firmware and have the current stable version and I make sure the tip was clean as well.
fbrc8-erin 265
Since you're in the US, fbrc8 and your reseller are your local support, but the forums are also always a great options.
Have you updated the firmware since receiving your UM3?
Have you run the Z-offset calibration in the Maintenance menu?
Also, at the start of your print, are your starting with a clean nozzle tip on your core, or is there extra filament hanging off the end of it?
