but Cura 2.3 does not know the difference between a single extrusion and a multi extrusion print when a multi extrusion printer is active.
Unless you give it a single extrusion profile? something like that is needed anyhow to provide the full bed size for single extrusion, would be nice to ad one-at-a-time as well then... so at least it's available in single mode
ahoeben 1,986
With patience. It is impossible to bring the option back in 2.3.1 yourself, but it may return in a future version.
The reason that the feature has been disabled for the UM3 is that it would be very likely that the head would collide with a previous print if it would move to/from the extruder switch bay. This would not be a problem with single extrusion prints, but Cura 2.3 does not know the difference between a single extrusion and a multi extrusion print when a multi extrusion printer is active.
