could it be that he means the time that the steppers of the bed are blocked?
At least that is something that bothers me....
If you do something with the model, the bed suddenly moves down (if your bearings are real smooth..) and there is no way to continue at the right spot.
ahoeben 1,890
It should pause until you instruct your printer to continue (on the controller of your printer). There is no "pause time". What printer do you use?
