Ultimaker 2+ swapping material doesnt work...
Attenbach
Posted · Ultimaker 2+ swapping material doesnt work...
Hi guys,
so i started printing as usual, the plan was to resume the print after 7 hours with a different material as i used to do:
Pause it, select Change material etc.
Now this time after the 7 hours, i went throught that process again. When the Printer threw the old material out, i selected PLA as i always do (cause i print with PLA). Then though, it said:
Heating printhead for material Insertion.
then after some time, the "heating" changed into a "cooling" and then swapped between the two every second or so. Now i couldnt even resume the print as the material was already ejected. I had to factory reset the Printer, loaded the material and did a test print to see, whether the Problem still remained.
Now it did the same Thing again.
Is this a Software bug? I mean, all temperature sensors must be working fine since it started printing.
Any tips? I mean i could try to install the very latest Software update, since it didnt do the bug before i updated i a month ago or so...
Greets, Ka
        • 26 replies
