From these data can not be found.
2016-12-21 20:15:25,328 - INFO - Loaded plugin FileLogger
2016-12-21 20:15:25,359 - INFO - Loaded plugin GCodeProfileReader
2016-12-21 20:15:25,390 - INFO - Loaded plugin GCodeWriter
2016-12-21 20:15:25,422 - INFO - Loaded plugin ImageReader
2016-12-21 20:15:25,468 - INFO - Loaded plugin LayerView
2016-12-21 20:15:25,515 - INFO - Loaded plugin LegacyProfileReader
2016-12-21 20:15:25,562 - INFO - Loaded plugin LocalFileOutputDevice
2016-12-21 20:15:25,609 - INFO - Loaded plugin PerObjectSettingsTool
2016-12-21 20:15:25,656 - INFO - Loaded plugin PostProcessingPlugin
2016-12-21 20:15:25,718 - INFO - Loaded plugin RemovableDriveOutputDevice
2016-12-21 20:15:25,780 - INFO - Loaded plugin SliceInfoPlugin
2016-12-21 20:15:25,827 - INFO - Loaded plugin SolidView
2016-12-21 20:15:25,874 - INFO - Loaded plugin CameraTool
2016-12-21 20:15:25,936 - INFO - Loaded plugin MirrorTool
2016-12-21 20:15:25,999 - INFO - Loaded plugin RotateTool
2016-12-21 20:15:26,077 - INFO - Loaded plugin ScaleTool
2016-12-21 20:15:26,124 - INFO - Loaded plugin SelectionTool
2016-12-21 20:15:26,180 - INFO - Loaded plugin TranslateTool
2016-12-21 20:15:26,243 - INFO - Checking for new version of cura
2016-12-21 20:15:26,243 - INFO - Loaded plugin UpdateChecker
2016-12-21 20:15:26,573 - INFO - Found a new version of the software. Spawning message
2016-12-21 20:15:26,573 - INFO - Loaded plugin USBPrinting
2016-12-21 20:15:26,635 - INFO - Loaded plugin SimpleView
2016-12-21 20:15:26,698 - INFO - Loaded plugin WireframeView
2016-12-21 20:15:26,776 - INFO - Loaded plugin XRayView
2016-12-21 20:15:26,776 - INFO - Command line arguments: {'debug-mode': False, 'external-backend': False, 'file': [], 'disable-textures': False}
2016-12-21 20:15:26,807 - DEBUG - Attempting to connect to COM8
2016-12-21 20:15:26,979 - ERROR - An exception occurred loading Machine Instance: C:\Users\Tadej/AppData/Local/cura\machine_instances\Ultimaker+Original.stack.cfg: File C:\Users\Tadej/AppData/Local/cura\machine_instances\Ultimaker+Original.stack.cfg is an invalid settings file
2016-12-21 20:15:27,365 - DEBUG - Attempting to kill the engine process
2016-12-21 20:15:27,365 - WARNING - Old config file found, ignoring
2016-12-21 20:15:27,553 - DEBUG - Attempting to connect to printer with serial COM8 on baud rate 115200
2016-12-21 20:15:27,646 - INFO - Started engine process: C:\Program Files\Cura 2.1\CuraEngine.exe
2016-12-21 20:15:27,677 - DEBUG - Setting active view to SolidView
2016-12-21 20:15:29,439 - DEBUG - Loaded theme C:\Program Files\Cura 2.1\resources\themes\cura
2016-12-21 20:15:30,357 - DEBUG - Backend connected on port 49675
2016-12-21 20:15:30,865 - DEBUG - Initialized OpenGL subsystems.
2016-12-21 20:15:30,866 - DEBUG - OpenGL Version: 2.1.8304 Release
2016-12-21 20:15:30,866 - DEBUG - OpenGL Vendor: ATI Technologies Inc.
2016-12-21 20:15:30,866 - DEBUG - OpenGL Renderer: ATI Mobility Radeon X1300
2016-12-21 20:15:34,182 - DEBUG - Attempting to connect to printer with serial COM8 on baud rate 250000
2016-12-21 20:15:35,905 - INFO - Printer connection listen thread started for COM8
2016-12-21 20:15:35,905 - INFO - Established printer connection on port COM8
2016-12-21 20:15:41,035 - DEBUG - Autosaving preferences, instances and profiles
2016-12-21 20:15:41,035 - WARNING - No active machine found when trying to save setting visibility
2016-12-21 20:15:51,126 - WARNING - No active machine found when trying to save setting visibility
2016-12-21 20:15:52,309 - DEBUG - Calculating normals took 0.19601106643676758 seconds
2016-12-21 20:15:52,310 - DEBUG - Loaded a mesh with 10452 vertices
2016-12-21 20:15:52,960 - DEBUG - Attempting to kill the engine process
2016-12-21 20:15:52,960 - DEBUG - Killing engine process
2016-12-21 20:15:52,964 - DEBUG - Engine process is killed. Recieved return code 1
2016-12-21 20:15:53,409 - INFO - Backend crashed or closed. Restarting...
2016-12-21 20:15:53,516 - DEBUG - Attempting to kill the engine process
2016-12-21 20:15:53,624 - INFO - Started engine process: C:\Program Files\Cura 2.1\CuraEngine.exe
2016-12-21 20:15:53,821 - DEBUG - Backend connected on port 49675
2016-12-21 20:15:56,728 - DEBUG - Setting nozzle temperature to 0
2016-12-21 20:15:59,802 - DEBUG - Setting nozzle temperature to 0
2016-12-21 20:16:00,608 - DEBUG - Moving head to 0, 0 , 3
2016-12-21 20:16:03,643 - DEBUG - Autosaving preferences, instances and profiles
2016-12-21 20:16:20,381 - WARNING - Serial timeout while writing to serial port, trying again.
2016-12-21 20:16:20,896 - ERROR - Unexpected error while writing serial port Write timeout
2016-12-21 20:16:20,896 - DEBUG - Closing the printer connection.
2016-12-21 20:16:20,896 - INFO - Printer connection listen thread stopped for COM8
2016-12-21 20:16:46,199 - DEBUG - Autosaving preferences, instances and profiles
2016-12-21 20:18:36,643 - DEBUG - Calculating normals took 0.1410079002380371 seconds
2016-12-21 20:18:36,661 - DEBUG - Loaded a mesh with 10452 vertices
2016-12-21 20:18:37,277 - DEBUG - Attempting to kill the engine process
2016-12-21 20:18:37,277 - DEBUG - Killing engine process
2016-12-21 20:18:37,283 - DEBUG - Engine process is killed. Recieved return code 1
2016-12-21 20:18:37,717 - INFO - Backend crashed or closed. Restarting...
2016-12-21 20:18:37,824 - DEBUG - Attempting to kill the engine process
2016-12-21 20:18:37,879 - INFO - Started engine process: C:\Program Files\Cura 2.1\CuraEngine.exe
2016-12-21 20:18:37,947 - DEBUG - Backend connected on port 49675
2016-12-21 20:18:38,506 - DEBUG - Attempting to kill the engine process
2016-12-21 20:18:38,506 - DEBUG - Killing engine process
2016-12-21 20:18:38,511 - DEBUG - Engine process is killed. Recieved return code 1
2016-12-21 20:18:38,531 - INFO - Backend crashed or closed. Restarting...
2016-12-21 20:18:38,638 - DEBUG - Attempting to kill the engine process
2016-12-21 20:18:38,696 - INFO - Started engine process: C:\Program Files\Cura 2.1\CuraEngine.exe
2016-12-21 20:18:38,768 - DEBUG - Backend connected on port 49675
2016-12-21 20:18:57,874 - DEBUG - Setting active view to LayerView
2016-12-21 20:19:00,792 - DEBUG - Autosaving preferences, instances and profiles
2016-12-21 20:19:17,350 - DEBUG - Calculating normals took 0.0 seconds
2016-12-21 20:19:17,351 - DEBUG - Loaded a mesh with 972 vertices
2016-12-21 20:19:17,358 - DEBUG - Loading mesh took 0.2102060317993164 seconds
2016-12-21 20:19:18,143 - DEBUG - Attempting to kill the engine process
2016-12-21 20:19:18,143 - DEBUG - Killing engine process
2016-12-21 20:19:18,148 - DEBUG - Engine process is killed. Recieved return code 1
2016-12-21 20:19:18,390 - INFO - Backend crashed or closed. Restarting...
2016-12-21 20:19:18,498 - DEBUG - Attempting to kill the engine process
2016-12-21 20:19:18,576 - INFO - Started engine process: C:\Program Files\Cura 2.1\CuraEngine.exe
2016-12-21 20:19:18,646 - DEBUG - Backend connected on port 49675
2016-12-21 20:19:21,443 - DEBUG - Backend quit with return code 0. Resetting process and socket.
2016-12-21 20:19:21,498 - INFO - Started engine process: C:\Program Files\Cura 2.1\CuraEngine.exe
2016-12-21 20:19:21,623 - DEBUG - Backend connected on port 49675
2016-12-21 20:19:27,620 - DEBUG - Autosaving preferences, instances and profiles
2016-12-21 20:19:43,438 - DEBUG - Autosaving preferences, instances and profiles
2016-12-21 20:23:08,804 - DEBUG - Shutting down cura
2016-12-21 20:23:12,403 - ERROR - Exception while emitting shutdown signal: NotImplementedError('Stop should be implemented by subclasses',)
2016-12-21 20:23:12,403 - DEBUG - Attempting to kill the engine process
2016-12-21 20:23:12,403 - DEBUG - Killing engine process
2016-12-21 20:23:12,403 - DEBUG - Engine process is killed. Recieved return code 1
2016-12-21 20:23:16,697 - INFO - Loaded plugin FileLogger
2016-12-21 20:23:16,744 - INFO - Loaded plugin GCodeProfileReader
2016-12-21 20:23:16,791 - INFO - Loaded plugin GCodeWriter
2016-12-21 20:23:16,838 - INFO - Loaded plugin ImageReader
2016-12-21 20:23:16,894 - INFO - Loaded plugin LayerView
2016-12-21 20:23:16,940 - INFO - Loaded plugin LegacyProfileReader
2016-12-21 20:23:16,987 - INFO - Loaded plugin LocalFileOutputDevice
2016-12-21 20:23:17,065 - INFO - Loaded plugin PerObjectSettingsTool
2016-12-21 20:23:17,143 - INFO - Loaded plugin PostProcessingPlugin
2016-12-21 20:23:17,237 - INFO - Loaded plugin RemovableDriveOutputDevice
2016-12-21 20:23:17,315 - INFO - Loaded plugin SliceInfoPlugin
2016-12-21 20:23:17,377 - INFO - Loaded plugin SolidView
2016-12-21 20:23:17,458 - INFO - Loaded plugin CameraTool
2016-12-21 20:23:17,528 - INFO - Loaded plugin MirrorTool
2016-12-21 20:23:17,621 - INFO - Loaded plugin RotateTool
2016-12-21 20:23:17,699 - INFO - Loaded plugin ScaleTool
2016-12-21 20:23:17,794 - INFO - Loaded plugin SelectionTool
2016-12-21 20:23:17,872 - INFO - Loaded plugin TranslateTool
2016-12-21 20:23:17,950 - INFO - Checking for new version of cura
2016-12-21 20:23:17,950 - INFO - Loaded plugin UpdateChecker
2016-12-21 20:23:18,106 - INFO - Loaded plugin USBPrinting
2016-12-21 20:23:18,184 - INFO - Found a new version of the software. Spawning message
2016-12-21 20:23:18,199 - INFO - Loaded plugin SimpleView
2016-12-21 20:23:18,293 - INFO - Loaded plugin WireframeView
2016-12-21 20:23:18,386 - INFO - Loaded plugin XRayView
2016-12-21 20:23:18,386 - INFO - Command line arguments: {'file': [], 'debug-mode': False, 'disable-textures': False, 'external-backend': False}
2016-12-21 20:23:18,433 - DEBUG - Attempting to connect to COM8
2016-12-21 20:23:18,875 - ERROR - An exception occurred loading Machine Instance: C:\Users\Tadej/AppData/Local/cura\machine_instances\Ultimaker+Original.stack.cfg: File C:\Users\Tadej/AppData/Local/cura\machine_instances\Ultimaker+Original.stack.cfg is an invalid settings file
2016-12-21 20:23:18,875 - WARNING - No active machine found when trying to save setting visibility
2016-12-21 20:23:18,875 - DEBUG - Attempting to kill the engine process
2016-12-21 20:23:19,482 - DEBUG - Attempting to connect to printer with serial COM8 on baud rate 115200
2016-12-21 20:23:19,671 - INFO - Started engine process: C:\Program Files\Cura 2.1\CuraEngine.exe
2016-12-21 20:23:19,734 - DEBUG - Setting active view to SolidView
2016-12-21 20:23:20,239 - DEBUG - Calculating normals took 0.0 seconds
2016-12-21 20:23:20,239 - DEBUG - Loaded a mesh with 10452 vertices
2016-12-21 20:23:21,714 - DEBUG - Loaded theme C:\Program Files\Cura 2.1\resources\themes\cura
2016-12-21 20:23:23,740 - DEBUG - Backend connected on port 49674
2016-12-21 20:23:24,372 - DEBUG - Initialized OpenGL subsystems.
2016-12-21 20:23:24,373 - DEBUG - OpenGL Version: 2.1.8304 Release
2016-12-21 20:23:24,373 - DEBUG - OpenGL Vendor: ATI Technologies Inc.
2016-12-21 20:23:24,374 - DEBUG - OpenGL Renderer: ATI Mobility Radeon X1300
2016-12-21 20:23:26,468 - DEBUG - Attempting to connect to printer with serial COM8 on baud rate 250000
2016-12-21 20:23:28,212 - INFO - Printer connection listen thread started for COM8
2016-12-21 20:23:28,212 - INFO - Established printer connection on port COM8
2016-12-21 20:23:34,731 - DEBUG - Autosaving preferences, instances and profiles
2016-12-21 20:23:56,407 - DEBUG - Calculating normals took 0.0 seconds
2016-12-21 20:23:56,407 - DEBUG - Loaded a mesh with 1560 vertices
2016-12-21 20:23:56,429 - DEBUG - Loading mesh took 0.2910120487213135 seconds
2016-12-21 20:23:57,175 - DEBUG - Attempting to kill the engine process
2016-12-21 20:23:57,175 - DEBUG - Killing engine process
2016-12-21 20:23:57,175 - DEBUG - Engine process is killed. Recieved return code 1
2016-12-21 20:23:57,175 - INFO - Backend crashed or closed. Restarting...
2016-12-21 20:23:57,284 - DEBUG - Attempting to kill the engine process
2016-12-21 20:23:57,342 - INFO - Started engine process: C:\Program Files\Cura 2.1\CuraEngine.exe
2016-12-21 20:23:57,498 - DEBUG - Backend connected on port 49674
2016-12-21 20:24:00,127 - DEBUG - Backend quit with return code 0. Resetting process and socket.
2016-12-21 20:24:00,215 - INFO - Started engine process: C:\Program Files\Cura 2.1\CuraEngine.exe
2016-12-21 20:24:00,383 - DEBUG - Backend connected on port 49674
2016-12-21 20:24:05,888 - DEBUG - Setting active view to XRayView
2016-12-21 20:24:06,677 - DEBUG - Autosaving preferences, instances and profiles
gr5 2,189
The log file is your friend. Something similar to:
C:\Users\Otis\AppData\Local\cura\cura.log
Edited by GuestLink to post
