Adding Profiles in Cura
JTBrown
Posted · Adding Profiles in Cura
One way to add a profile is to modify an existing one then click on the Profile drop-down and select "Create profile from current settings..." (that option isn't enabled until you change something in the current profile)
Hope this helps.
    Hope this helps.
    Thanks, I have done that but when I go to manage profiles there are no profiles in the list
