I have Cura 15.04.6, and checking for update inside Cura I read that I've got the newest version.
The settings are as following:
- layer height are 0.2mm, shell thickness 0.8mm, and bottom/top thickness 0.6mm, nozzle size 0.4.
That should work, shouldn't it?
@ pictures good point, my server is on the ISS ;-)
I am quite a newbie with uploading pictures, so if you can recommend me a server on earth I'd be grateful; and, BTW, what do your mean with UMO?
gr5 2,069
Those pictures are taking too long to load. I think you posted them on a server on the moon.
From what I can see so far the yellow part agrees with your text. There is a top/bottom thickness and such that must have gotten unchecked or set to zero. I forget where it is in cura 2.3 but I've seen it - it's near settings about shell thickness.
Do you have cura 2.3.*? For UMO I recommend cura 15.04.*
