You do not require a Stainless nozzle to print abrasive filaments, but if you use the UM3, the print cores do have brass nozzles and they will wear out pretty fast. And since you can not change the nozzle of the print core yourself, it will be pretty expensive to print abrasive filaments with the UM3, changing a few print cores per kilo printed if your material is really abrasive.
The stainless nozzles are actually only about 3 times as wear resistant as brass, and will still wear out pretty fast, i wore out a stainless nozzle in almost 1kg of material when testing, where the brass one lasted about 300g. (test was done with Colorfabb XT-CF20)
If you want to really print abrasives you should look at hardened steel or ruby tipped nozzles. None of these options are available for the UM3 at the moment though, right now the UM2+ is the better option for abrasives.
Edited by Guest-
1
neotko 1,417
Yes you can but indeed the actual cores would get the nozzle damage overtime by the abrasive materials.
Ofc there will be other cores in the future and third prty designs in the future.
Edited by GuestLink to post
