Thank you korneel for your replay,
We use ult 2+
PLA
CURA
0.4mm noz.
60 micron
thanks
Hmmm, while some shrinkage is normal, 3% seems to be a bit too much.
Which version of Cura do you use? some 15.* versions are notorious on "shrinking" the sizes.
Also, some PLA brands shrink more than others.
If you are in for some tests, try to use older Cura 14 and dry the PLA as much as you can before usage. An hour in oven pre-heated to about 45-50C should suffice.
That what I would do, anyways.
korneel 175
well, what is the material you print with, which slicer do you use, and which printer do you use?
