Hi SandervG
Yes ran Wifi from start again, it can not create the hotspot needed to input the wifi details.
Have waited hours with no response. In update to this it sometimes does manage to turn on, seemingly randomly. Try turning it on 10-15 times with nothing then it will work. Turn it off again and it can not turn on for a while, then it will work...
Hi @mmacinnis,
Welcome to the forums! I'm sorry to hear you seem to have some troubles.
Have you ran the wifi set up from the start again? Do you get some error messages or what will happen?
l regard of your print core, how long have you waited after turning on your Ultimaker 3? Because the Ultimaker 3 has a big brain, it takes approx 40 seconds for it to start up. First the fans will turn on, and then the rest will follow.
Have waited long enough to see this happen?
SandervG 1,518
Hi @mmacinnis,
