I still like this one, although on some materials a bit more friqtion is better to stop the spool from spontaneous unwinding...
https://www.youmagine.com/designs/low-friction-um2-spoolholder
On the UM3 I like to keep 1 spool on the back , and the 2th spool on the side. Used the spoolholder, but directly mounted to a piece of plywood. It fits the 1 Kg Extrudr green-tec spools.
thx so much bro
picture is a UM2+ but its the same setup
Spool for Ultimaker 3
This reel is great. But I'm looking for something that does not require threaded rods or other hardware.
We have several length spool holders designed around the original UM2. I think this should fit on the UM3
http://www.thingiverse.com/thing:1672064
Hope this helps.
ultiarjan 1,221
Edited by GuestLink to post
