Heated blue tape
greengecko
Posted · Heated blue tape
could not find an answer to this probably earlier asked question.
So, to avoid warping and to have a sometimes prefered non-shiny smooth surface at the buttom, does it help to print PLA on a layer of heated blue tape?
If so what is a good temperature to start with.
Thanks in advance,
greengecko
    A heated bed with blue tape works like a charm. But you need to be sure not to press the PLA into the tape as you do with a cold bed with tape, else you will rip up the tape in notime.
    Heated bed temperature for PLA is around 70C, but depending on your bed you need to experiment a bit.
        • 56 replies
        • 29 replies
