I started turning the bed more towards the nozzle and this seemed to do the trick first print stuck properly and completed fully. Also I started using abs juice on the glass plate, this seems to also help quite a bit.
However the second print which took a lot longer and is a lot higher started hitting the nozzle once it reached roughly 15mm. Any idea why this can be, did I move the bed up to much to the nozzle?
Find it strange i have to manually do this for an ABS print, why cant cura/ultimaker do this automatically for me.
I have also ordered some ultimaker ABS supposedly this is a lot better, will have a see tomorrow if this make a difference.
gr5 1,504
Definitely increase bed temp to 100C but your main problem is most likely that the nozzle is too far from the build plate. Try simply turning the 3 bed leveling screws 1/3 turn counter clockwise (as seen from below) and try again. If it's still not working turn another 1/3 while it's printing the first layer. Turn them equal amounts. Much more details here:
You will have a few other issues with ABS - most notably you will probably find that the layer bonding is weak. That is fixed by enclosing your printer or turning the fan down to about 3% (on UM3, 30% on UM2). Or both.
Many people don't notice the layer bonding issue until their 100th print when they find out how much weaker ABS is than PLA.
