Anything?
fbrc8-erin 266
I have similar problem. Did you find a solution to the problem?
What firmware are you running? Run the latest stable version.
1
- 1 month later...
Same problem here, any known solutions?
fbrc8-erin 266
Have you tried a factory reset?
Is this happening during prints, or just the XY calibration?
1
Did anyone figure out the solutin to this . I am facing the same issue. The printer restarts when I try to XY calibrate.
It would be great if the ultimaker teams responds .
Thanks
@EWadsager, @bizzarrini and @sameeryel
What @fbrc8-erin and @neotko have been suggesting are the right steps.
1. Check your current firmware.
2. Update to the latest stable.
If the problem then still persists. we'd like to receive the log files.
neotko 1,417
I would update the firmware. Maybe yours has an older version. Afaik they solved that issues.
EWadsager 0
