Dear Newbe,
Many, many thanks for your reply and kind help!!!!!!
I will try this on tomorrow and keep you informed.
Fred
Dear Newbe,
Fred
I never touch the z-limit switch. Due to wood changing with the climate, the table needs to be tuned every now and then. I use the 4 screws on the bed for that.
Just manually turn the z-screw until you hear the click of the switch. Then move your head to all 4 corners, and turn the adjustment screw so that the head just touches the papersheet.
gr5 2,334
I'm not sure if you are talking about before printing or during printing.
If before printing: You can adjust the home height by sliding the homing switch up and down. On the back of the UM there is a "Z limit switch". It can slide up and down. With power off, Loosen the screws so the switch slides up and down in the slot. Rotate the z platform until it touches the nozzle. Slide the switch down until it clicks (or a little more down). Tighten the screws. If you can't get the limit switch to click then you built something wrong. Did you include the plastic printing bed? Please send a picture of your bed and another picture of the print head.
If during printing: When you tell Cura the first layer is .3mm, it sets the z axis to .3mm to allow room for the PLA to come out. This is normal. If you tell cura the first layer is .1mm, then the z axis is set to .1mm. If you have an ulticontroller you can see this on the ulticontroller screen during printing.
