Thermocouple Temperature Control Board PLUG REPLACEMENT plus other parts
mechaneil
Posted (edited) · Thermocouple Temperature Control Board PLUG REPLACEMENT plus other parts
I need to replace just the plug (white plug) on the Thermocouple Temperature Control Board on my UMO as well as other parts.
http://imgur.com/a/2Y3XV
Are these good and SAFE replacements?
http://www.ebay.com/itm/282317086994
http://www.ebay.com/itm/122317311108
http://www.ebay.com/itm/291762331003?var=590777916845
    Posted · Thermocouple Temperature Control Board PLUG REPLACEMENT plus other parts
    The connector is a JST-XH, you should be able to find that easily.
    For the other parts, I would recommend to stay away from cheap copies, most of them are poor quality. One missed print and you will loose the benefit...
    Thanks for the reply. Will this work?
    http://www.ebay.com/itm/5-Sets-520cm-JST-XH-2-5-3-Pin-connector-plug-Male-RC-Li-Po-Battery-US-Seller-/172491406332?hash=item282949fbfc:g:rjUAAOSwx2dYHOsC
