It is possible to turn of the automatic leveling, by doing a manual level. But why would you still want to measure but not actually use the data that you get from it? In that case it would be better to skip the measuring all together.
If you do manual bed leveling, you also manually calibrate the nozzle offset. If you don't move around your printer often or switch cores, you should not need to calibrate all that often.
Ok. So if I just do a manual leveling, and switch off the auto level, then when I print, the printer should not adjust the z axis during the print at all?
nallath 1,124
