Could be a Cura bug. There is a bug related to the "minimal feedrate" setting in the expert settings. Any version less then 13.01 it's best to set this value to 0. (This bug only happens when you have very small layers)
Ah ok that makes sense. Layer height was 0.1. Where do I get the latest cura? I have 12. something from before christmas.
I took everything apart and pulled everything out of the nozzle. It looked all just like pla, no dirt or other plastic.
There will be a stable release out tomorrow.
Thanks Daid, do you know the time of the day?
Oh Daid, and you know what would be cool? If Ultimaker was to offer a Laser Cut Tool Holder that you can slide on the side of the ultimaker. So you can place all your pliers, knifes and tweezers in there.
Just set "minimal layer time" to 0 seconds and the bug won't affect you. Try printing only the very top of your part if you want to test that the fix works.
Thanks, changed it and it is printing right now. Looks good so far.
edis 0
Maybe there was a jam of some kind? Dust. etc. And by pushing with hand, you provided enough pressure to push that dust plug out?
