Well I see two issues - the tripod legs are underextruded. I'm really not sure why that looks so good yet the part just above and below looks fine. Maybe you have infill speed set at a higher speed. That could cause the tripod legs problem (and also the stringing issue).
The other issue is what I call "stringing". That shouldn't happen. It could be several things:
1) It could be cura is not doing retractions because it really hasn't printed much since the last retraction and one of the settings in cura is how much filament to print before retractions can occur. This keep the exact same spot of filament from not being retracted hundreds of times. If your retraction distance is 4.5mm and the minimum print before retraction is 0.45 then it will do no more than 10 retractions (4.5/.45) on each spot of filament. But for this part I think you need to lower it. In cura 15.X you can check in layer view as retractions are shown as vertical blue lines (strange but it works for me).
2) It could be that your have a long bowden or a large inner diameter bowden or a loose bowden (when you pull up on it it shouldn't move up and down - if it does it is not properly seated in the print head or feeder). If so maybe increase your retractino distance from default of 4.5mm to say 7mm (but of course if there are no retractinos here then that won't help).
3) lowering temperature helps reduce stringing.
4) Printing slower reduces the pressure in the head and so reduces strings. This will help with underextrusion and other quality issues. Try printing nice and slow at say 25mm/sec.
gr5 1,969
Please next time post a picture instead of an imgur link that will not still be around 5 years from now when other's might come looking at this topic.
