I never heard of the build plate warping but a warped build plate is possible. I had a lot of problems with ABS warping off the build plate. I started using
the blue painters tape after I use a squeegee to make sure the tape is flat I use
isopropyl alcohol to whip the top of the tape to remove the sheen. Ever since I never had a warped part. For large parts fill the glass with tape and wrap it around the edge.
My part stuck so good it took soaking it in hot water to soften the tape, took about 30minutes to remove.
Hope this helps,
Frank
MechDesigner 3
Tom,
Hope this helps,
Frank
