I am following up here, because I am having the problem in Cura 2.4, and the above thread is specific to Cura 2.3.
I get two messages: Auto scaled object to 16% of original size and Nothing to slice because none of the models fit the build volume. Please scale or rotate models to fit.
If Cura is going to scale my model to fit, when Cura is done, the result should fit. When I manually scaled the object to 14%, Cura successfully sliced the model.
peggyb 169
here is some more info on the subject:
https://ultimaker.com/en/community/23300-cura-23-not-using-full-print-area?page=1#unread
