Wire-printing on a Delta?
peggyb
Posted (edited) · Wire-printing on a Delta?
Can somebody help me before doing something stupid?
I did some little tests with wire printing (experimental tab) on the UM2+, this looks good and with some tweaking it is possible to achieve something acceptable.
This is a 6 cm small torso, but I a have a big Delta printer available and want to try this at 50 cm (life size). Now I noticed with the UM2+ that the buil plate/z axes takes care of the 'wire' movements. With a Delta the bed is fixed and the arms move; does wire printing the same on a UM as on a Delta?
part of the gcode (think it looks good, doing z movements from Z1 to Z21 and back):
;LAYER:1
M106 S255
;TYPE:SUPPORT
G1 F1200 E6976.01195
G0 F2400 X1.346 Y97.167 Z20.1
G0 X1.346 Y97.167 Z1
G1 F1200 E6996.01195
G92 E0
G1 F326.1 X2.565 Y90.78 Z21.948 E20.18124
G1 F300 X-1.605 Y92.708 E24.77538
G1 X-18.285 Y100.424 Z1 E52.64252
G4 P500
G1 F150 X-18.285 Y100.424 Z2 E54.64252
G1 F324.3 X-19.46 Y92.783 Z21.95 E74.43592
G1 F300 X-23.827 Y95.183 E79.41896
G1 X-41.299 Y104.786 Z1 E108.33938
G4 P500
G1 F150 X-41.299 Y104.786 Z2 E110.33938
G1 F324.5 X-41.051 Y96.423 Z21.951 E130.34247
G1 F300 X-45.701 Y98.237 E135.33377
G1 X-64.303 Y105.495 Z1 E164.27609
G4 P500
G1 F150 X-64.303 Y105.495 Z2 E166.27609
G1 F322.7 X-62.94 Y97.041 Z21.952 E186.45901
G1 F300 X-68.124 Y96.723 E191.65275
G1 X-88.862 Y95.45 Z1 E221.15989
       etc.........
made a new machine in Cura 2.4 Delta style, entered the size and settings, the start and end code from the old Cura. Is there something else to change? This thing is big and I don't want a big mess...
    Posted · Wire-printing on a Delta?
    There's no reason I can think of it should not work, but first try to print a normal model using your delta with Cura 2.4. If that does not work, neither will wireprinting.
    Note that you may need to make some changes to the start/end gcode before it works with Cura 2.4; specifically most {replacement_patterns} have changed
    Thanks for answering..
    I copied the sart and end code from 15.04, does it look OK? (no idea what you mean with {replacement_patterns}...)
    start;
    ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
    ;Print time: {print_time}
    ;Filament used: {filament_amount}m {filament_weight}g
    ;Filament cost: {filament_cost}
    ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
    ;M109 S{print_temperature} ;Uncomment to add your own temperature line
    G21 ;metric values
    G90 ;absolute positioning
    M82 ;set extruder to absolute mode
    M107 ;start with the fan off
    G28 X0 Y0 ;move X/Y to min endstops
    G28 Z0 ;move Z to min endstops
    G1 Z15.0 F{travel_speed} ;move the platform down 15mm
    G1 F200 E3 ;extrude 3mm of feed stock
    G1 F{travel_speed}
    ;Put printing message on LCD screen
    M117 Printing...
    end:
    M104 S0 ;extruder heater off
    M140 S0 ;heated bed heater off (if you have it)
    G91 ;relative positioning
    G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
    G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
    ;M84 ;steppers off
    ;{profile_string}
    Off the top of my head, {travel_speed} should be {speed_travel}. The others don't seem to be have a functional effect because they are commented out.
    the default Delta start code is:
    G28 ;Home
    G1 Z15.0 F6000 ;Move the platform down 15mm
    ;Prime the extruder
    G92 E0
    G1 F200 E3
    G92 E0
    should I use this one?
    it does say the same in values... although the description should not say: move the platform down... because it can't..
    @ahoeben
    you're reply was faster then my reply...
    the default start code has a fixed F6000 (too fast for this printer)
    so changing the "{travel_speed} should be {speed_travel}" would be enough?
