innovo3d 0 Posted March 1, 2017 in Can you connect to printer (non-Ultimaker) via Wifi? Hi. I'm just wondering if it's possible to connect to other printers via Wifi using Cura? I currently use Repetier Server and it supports Wifi connectivity and I would like to connect to it via Cura. Thanks, Adam Share this post Link to post Share on other sites
nallath 536 Posted March 1, 2017 in Can you connect to printer (non-Ultimaker) via Wifi? You can get octoprint to work almost (but not entirely) like the UM3 with Cura if you use the amazing plugin made by @ahoeben which can be found on https://github.com/fieldOfView/OctoPrintPlugin I think anyone made similar support for Repetier Server, but it should not be that much work. I'd gladly welcome a pull request or a plugin. Share this post Link to post Share on other sites
