Multi-color prints using Cura 2
gleblanc
Posted · Multi-color prints using Cura 2
I'm trying to print a multi-color print with my Ultimaker 3 extended, using Cura 2.3.1 on Windows. I've designed the 3 parts using OnShape, and downloaded them as separate STL files. I can load and see the STL files, and set the print core and material type for each part. When I try to merge the 3 parts, the main part shows up in the correct location, and one of the sub-parts drops in where it should. The second sub-part comes in at the same location as the first sub-part.
I've uploaded the STL files and some screenshots to Thingiverse:
https://www.thingiverse.com/thing:2145441
I can manually move the bolt 2 to the right location, but is there a better way?
    Why you want to merge 3 parts?
    The UM3 can print in 2 different colors/materials.
    You can try to merge 2 parts in an other 3D program...
    You can merge lots of parts and mix the 2 colored materials to make other colors.
    Did you draw them in the same part file or separate? Are the parts designed in the correct position to the origin in Onshape?
