Posted · How to replace the top of the print head assembly?
I broke the plastic top piece of the print head assembly on my Ultimaker 2 Go. I have a new top, but can't find instructions on how to replace it. I detached the bowden tube and unscrewed the 4 screws that hold the assembly together. My problem is how to detach the wires so that I can feed them through the opening in the new top piece. It looks like there is some sort of connector inside the the black mesh tube enclosing the wires, but I can't see how it works. Can anyone help me with this?
Thank you!
    Posted (edited) · How to replace the top of the print head assembly?
    https://github.com/Ultimaker/Ultimaker2
    Here's an UM2 assembly manual, it's a bit old but shows you how the thing is build.
    I this case I would not disconnect the wires/electronics, but just take apart the head, including the metal parts, take of the heaterblock/olsonblock, then you should be able to move the block through the black plastic parts.
    You may need to heat it up a bit to unscrew the hot end isolater, the metal part with the holes all around. You can screw/unscrew this thing also by sticking a small hex screwdriver in one of the holes.
    You'll find the hot end around page 48.
    Or you can cut with care a escape area on both so you can remove the top and insert a new one without disassembling anything.
    I hated to cut the new piece, but it seemed easier than dealing with all the wires, so I did it, and it worked. Thank you!
