Same issue here with 2.6.2 I can't get it completely removed and I can't even install ANY version successfully. Seems that Ultimaker isn't interested in helping either set up a work ticket but no reply
peetersm 124
UPDATE-
I repeated the "clean install" process one more time.
--------clean install as I currently understand it---------------------
1. uninstall all previous versions of cura 2.x using the uninstall.exe file in the C:\Program Files\Cura 2.x folder
2. delete (or rename/remove) this folder *username* \AppData\Local\cura
3. Install the new version.
AND I'm on my second day of cura remembering the printers, even after reboots. Hopefully the 3rd time is the charm and what ever was wrong with the installation is now fixed
