Z-offset on Cura 2.4 ?
Posted · Z-offset on Cura 2.4 ?
Hi there!
I'm using Cura for a Kossel Mini (Marlin) and I was looking for a Z-offset value.
I use it to adjust really small values (0.2 to 0.5mm) depending on changes in the nozzle or whether I use painters tape or not. I tried to search for it on 'Machine settings' or the 'Custom print setup' without success.
Does it exist at all or should I look for a workaround?
Thanks in advance!
f
