Well, Cura already died for your sins; You don't have an active quality profile (as visible from not having a name in the profile dropdown) which means something already went horribly wrong.
Hi Kees,
What is the wall thickness of the manually added support? Is it 0.4mm? In that case in Cura 1.5.4 changing the line width to 0.39 was good enough in 1.5.4 but in 2.4 it is not. In 2.4 you need to change the nozzle size to 0.38 to get walls of 0.4mm.
I regulary use objects with 0.4mm lines.
Regards,
Eric
I checked the Thickness it's 0.7mm so should be no problem.
The thickness problem could show after slicing, but until now never happened in solid view..
[/quote
:( That's a minor detail .
The values change with the profiles, My own profiles do show, the standard UM ones don't
zoev89 73
Hi Kees,
Regards,
Eric
