Perhaps you're just looking for the wrong type of filament. Usually there's a difference between translucent and transparent (at least in my language). First one being pretty foggy and the latter should really be clear.
I've had good experience with transparent PETG from manufacturers like Extrudr, dasfilament and Primaselect. I've also tried HDglass from formfutura which I wasn't able to print without producing massive blobs and strings. However these companies are EU-based so this information might be useless if you're living in the US.
helpfulprinter 0
Hey Kman!
I've been looking for translucent PETG as well. The only thing that I've found to have similar properties is PCTG. It's very similar to PETG but when you print at high heat it becomes very transparent. There's a good blog explaining the similarities here.
Hope this helps!
