Learning from the Noobverse for all the noobs having fun with the UM3
Posted
(edited)
· Learning from the Noobverse for all the noobs having fun with the UM3
Well, almost time to roll out the models. Below is the 1/4th sized instructions as a preview. When I printed the full size model, it ran into a problem (temporary under-extrusion) right at the deflector dish. So, that got me to thinking about providing a fix for people so they did not have to cut up the model themselves. THEN I got to thinking about printing without supports. THEN I got to thinking about the different ways it may need to be printed to get cleaner results at lower Resolution 3D Nozzles a.k.a. 0.2mm and larger. So, it is a 3 Pak! And, the second version has two different saucer configurations. Tabs are easy to sync up with the placements. Now that I have all of the parts for the Supersized and 14 Inch versions, I just have to get them together with the full sized instruction sheets and upload them. :PA most decidedly set of Retro designs.
Woulda done something like this, but I do not want to waste time illustrating it, nor will I crib other's artwork, even for a gag......
Never had a girlfriend that looked lovingly at MY models that way...sheesh...coulda been a contender!! LOL
kmanstudios 1,120
Edited by GuestLink to post
