The outside support is set with the"horizontal expansion" function.
Ultimaker uses these default settings with a huge amount of PVA because PVA does not stick to wel to PLA. This way there's a higher change of PVA on PVA connections, and less change of a failed print....
Thanks for the help. I checked the horizontal expansion & it was set to 0. & when I changed it' the cog seemed to get fuzzy/Bigger.
However I happened to change the "support overhang angle" to a higher angle from the preset 45' to 80' & it had the desired effect. with only support at the base of the cog rather than up the sides as well & I managed to get a print done without any messy foul ups..
thanks anyway
ultiarjan 1,223
Edited by GuestLink to post
R32ool 0
hi
thanks anyway
