Two issues with connectivity
Tiger91
Posted · Two issues with connectivity
There are two highly irritating issues with the UM3 that I would like to know how to fix:
-Sometimes, when I insert a USB into my UM3, if I go to "print" it won't show any files and instructs me to insert a USB or print over cura. I have to restart the printer in order for the files to show. How do I avoid this?
-Also an issue is the fact that sometimes CURA will become unable to detect my UM3 no matter how many times I refresh, or recreate a hotspot. The only way I'm able to fix it is to unplug my router for 5 minutes and then reset it. How do I fix this problem without all that crap?
Thanks
    Are you using Windows? If so, that's the problem. The work around is to manually add the IP in the connect with printer interface.
    The USB drive issue is (being) fixed. Try updating your firmware.
    Using W10 - the last time I tried to add the IP manually it wasn't able to find it though.
