UM3 - Following material overflow, Printcore enclosure won't close.
Posted
· UM3 - Following material overflow, Printcore enclosure won't close.
Just take it out. It helps with airflow a little but mostly it's purpose is if your part gets partly done and is vaguly shaped like a hokey puck and then comes loose it will slide around the build plate and filament will keep coming out of the nozzle and get up inside the head.
But if you avoid autolevel and your parts stick like hell to the glass or instead if you check your print's progress every 30 minutes then you are unlikely to run into that problem.
I guess I would order another one from fbrc8 but print without it.
disclaimer: please don't go after me if you ruin your head because it filled with plastic.
I mean I've been printing for years and never had this problem. But MANY other's have had this problem (hocky puck sliding around creating massive blob that enters the print head).
gr5 1,872
