Not sure about the freeze. Is the extruder retracting during the freeze? If so then try printing much slower - half the speed you were printing - actually try printing at 20mm/sec just to see how much better the quality is at the "freeze" spots.
Also what is your: nozzle width, layer height, print speed, print temperature. These 4 values interact and if you print too fast you will need to set the flow to 130% like you did.
Thanks for your reply.
Yes retaraction is on. Nozzle is 0.4, layer high is 0.1 print speed is 30mm/s and 20mm/s on uoter peremiter and the temperature is 205 and im printing with PLA.
this is YODa which is quite good printed with those settings but as you can see there is still a little gap in peremiters.[/media]
gr5 1,871
