Actually, it appears to have repaired itself in regards to the x-axis issues. Weird...
New problem: I have been attempting to print a 50mm box test. The PLA is balling up on the head and not adhering to the plate.
Edited by GuestActually, it appears to have repaired itself in regards to the x-axis issues. Weird...
Edited by GuestIf the filament isn't adhering to the plate but instead the nozzle then almost certainly you need to move glass closer to head. While printing the bottom layer push up and down on the glass to see if that helps. If so then just rotate the 3 leveling knobs the same amount.
Please put ultimaker2 in your settings so I dont' have to reread every thread I post in and can just double check what printer you have by your name.
gr5 2,333
It may be normal about the fans although I admit this is a very common problem. The fans on the sides often don't turn until you are on the second or even 5th layer. Try going into the TUNE menu during a print (or even before it starts when the printer is warming up) and playing with fan speed there. If it still doesn't work it's almost certainly in the connectors just above the head. Cut or slide back the plastic netting and there are white connectors in there. Two of the connectors are connected by a short loop (about 3 inches). Those go to the two side fans.
The third fan - you should test that also - that should turn on either when power comes on or anytime the nozzle is above 50C.
The x-axis is skipping? Can you provide more details? Like this?
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide
Like 9th (pink) or tenth (gray) photo at the above link?
