Thank you for your response. After investigating further, it does seem the nozzle is not touching the print bed when the print begins. The distance from the glass differs on each print file. Would that indicate a problem with a Cura setting on the files or a calibration problem with the printer?
I am using an Ultimaker 2, Cura 15.02.1, and Ultimaker brand PLA.
gr5 2,230
It looks like the nozzle isn't touching the print bed when you start the print. Is it? If it is then it looks like pretty soon (second or 3rd layer) the nozzle is *above* the print instead of touching it on future layers.
So the nozzle should be touching the glass when Z=0. There syhould be some kind of calibration procedure for this. What kind of printer is it?
Or you Z screw is moving much to fast such that when it should separate the nozzle and glass by an adittional .2mm it is instead moving maybe 2mm. If you think it's this second problem then move the Z 10mm and see if it actually moves about 10mm with some kind of ruler. Again - what kind of printer is this? Please put your printer type in your settings. It's okay if it's not an Ultimaker printer.
