Distribute Cura 2.5.0 to computers
rontje
Posted · Distribute Cura 2.5.0 to computers
Hi!
I need to be able to distribute Cura 2.5.0 to the users of the school i work at.
I would prefer a .msi file for installation.. is there one availible? Where can i find it?
If there is no .MSI file, is there any option on the .exe install file i can use to distribute the file to out computers silently?
    Posted (edited) · Distribute Cura 2.5.0 to computers
    No, there is not
    Unfortunately, as far as I know, there is not.
    If you can install the required msvcrt version, and don't need the Arduino drivers (or can install them in a silent way yourself), you should be able to just distribute the files. IE: install Cura on one machine, and then just distribute the files from Program Files/Cura 2.x to other computers.
    edit for more helpfulness
