Posted
· Ultimaker 2 power cut out when changing filament?
Hi Everyone,
I have managed to pin it down to the Hot head heater. If i go to heat that up it cuts out.
I checked the circuit board and it looks like the heater had come out of its green circuit holder. I have put it back in the correct hole but it seems to still be doing the same issue.
Could it be the heater has fried?
neo-ninja 1
Hi Everyone,
