On a Windows computer I could not find the Cura.exe file in the Cura folder.
That was the original reason for my question. Can you please confirm that you see the Cura.exe file in the Cura folder.
32Bit Windows or 64bit Windows?
32Bit Cura (pre 2.4) or 64 bit Cura?
Cura 2.x or Cura 15.x?
They all go in different folders depending on the name, version, OS bit level and program bit level.
For 64bit Cura on Windows 64bit OS its:
. C:\Program Files\Cura 2.5\Cura.exe C:\Program Files\Cura 2.4\Cura.exe ...
For legacy 32bit versions of Cura 2.3 and earlier on 64bit Windows its:
. C:\Program Files (x86)\Cura 2.3\Cura.exe C:\Program Files (x86)\Cura 2.2\Cura.exe ...
For Cura 15.x, its called Cura.bat as it executes a Python script to run:
. C:\Program Files (x86)\Cura_15.04.4\Cura.bat
Hope this helps.
Edited by Guestkmanstudios 1,120
All excellent points....or...maybe just do a search?32Bit Windows or 64bit Windows?
- 1 month later...
Thank you for the information. I think the problem is that I was installing Cura on my D drive. I installed it on my C drive and now I see Cura. exe
kmanstudios 1,120
Depends on your operating system.
In Windows, it would be in 'Program files' in a folder that is the name of the version of Cura you are using.
It is cura.exe
I have not been on a MAC in a while, so no help there, sorry.
