That lower photo above has walls that are too thin for the printer I think. Try setting "line width" in cura 2.X to a smaller value just to see if that is the issue. If so try the largest possible nozle size where it still prints.
If your resulting nozzle size is smaller than .28mm then I would opt for a smaller nozzle. 3dsolex sells .25mm nozzles for um3. If a line width of .30 makes cura happy (or hopefully larger) then you should be fine with the .4mm nozzle. Consider maybe setting flow rate to 200% or so to compensate. You can experiment during the print in the TUNE menu to see how changing flow rate changes the look of the walls of that cowling (or whatever it is).
gr5 2,194
