I tried reproducing in Cura v2.6.1 and can't reproduce the reported issue. Can you confirm it still exists?
Cura 2.6 - bogus M104 S200 after first layer prints, despite specified temperatures.
- 3 weeks later...
yellowshark 153
I have always suffered the same type of thing with 2.4R. The gcode always sets temp to 210, irrespective of what I have entered in the Cura settings. To be honest I have not spent much time trying to find where it is coming from as I just mod the gcode before the starting the print as I need to mod the gcode for the z-offset command anyway from modify printer settings bug in 2.4
(Tried a reply and forgot to check the "Not a robot" box, so sorry is this is duplicated.)
Cura 2.6 has a lot of settings that are hidden and will assume a default value if another value isn't specified by the user (like "Initial Printing Temperature"). I would guess that that is where your M104 S200 is coming from. To track it down, open the Settings Visibility and do a search for Temperature, then check all of them to make them visible. Go back to your main page and look for a temperature setting with a value of 200. Change it to something more appropriate (like 220) and recompile. See if the M104 S200 is gone (and you find something like M104 S220).
CarloK 204
I did a few tests but can't reproduce your problem. However, it looks like there is a problem with the 'Default Printing Temperature' setting. On my system that value is ignored and exports 200C instead.
As a workaround you might try:
Just to be sure, Cura 2.6 isn't out yet. I believe you mean Cura v2.6-Beta?
