I don't think measuring wall thickness is an accurate way of measuring extrusion amount. Weighing an object is probably more accurate.
Well when you dont have a scale that can read Sub grams, and all cura says is ~1g, weighing it is not really an option. There has to be a better way.
1
I recently had issues with over-extrusion using ABS. My UM2 settings give ABS a 107% multiplier for ABS, but that was much too much on my new Type A Series 1 Pro.
On the S1, even a 103% multiplier caused winkling and bumps in the prints.
I'm guessing that this might be a difference between the UM2 remote-extruder with Bowden, and the S1, with 3" direct to the hotend.
changedsoul 2
Bump
