But be careful - you are already pretty low at 200C. I strongly recommend you do a simple test like the one I did in the above post as all PLAs are not the same both manufacturer and color. I'm told it helps to have a good quality PLA.
If you lower the temperature more you might get underextrusion which would mean you would have to lower the speed also although 50mm/sec would be plenty slow enough for me at 190C (100mm/sec would be a bit too fast for my grape colored PLA). This is also addressed at the above link.
Also you might want to add a clip: There's a blue clip on the print head where the bowden tube connects. You might want to make a similar one on the feeder. Other people seem to think this helps reduce how much you have to retract. I have one and 4.5mm is plenty for me.
Also 40mm/sec might be too fast for the retraction speed with the latest Marlin. I'm not sure - there's been discussion about this lately but I don't have the latest marlin so I haven't touched that setting.
But really I suspect the only thing you need to do is lower temp by 10C but don't waste another hour on this - do a test print first.
Oh - and to get better adhesion to the blue tape, wash it once with Isopropyl alcohol (aka rubbing alcohol) - found at any drugstore that sells aspirin and bandages. If you do that you shouldn't need to sink the bottle by 3mm.
gr5 2,224
You have "stringing". The simplest thing to do to reduce stringing is to lower temperature:
http://umforum.ultimaker.com/index.php?/topic/1872-some-calibration-photographs/
