While I don't have an answer for you, I would reach out to fbrc8 in the US. They offer support for the UM3 and are very quick to reply. There is also a facebook group https://www.facebook.com/groups/Ultimaker3 where Erin from fbrc8 is quick to help out as well.
I had a look at mine, the lens is of the screw on type, so I assume if it's not screwed in enough or too much it will be out of focus. I can't adjust mine, so it may have a bit of glue in it, not sure but I don't want to put much force on it...
I'm sure fbrc8 will help, if they send you a new unit it's super easy to replace, just a few screws and one connector. You may want to check if you can adjust yours....
skrotzkn, go ahead and try the adjustment if you feel comfortable doing so. Otherwise, it's a pretty quick and easy process to replace camera, and it can arranged if you email our team at Support@fbrc8.com.
1
The3DPrintStudio 5
ultiarjan 1,223
fbrc8-erin 287
Thanks, Ultiarjan, The3DPrintStudio.
